Question
Error message:
Error: DgnV8Bridge_0003
"File is already synchronized using a different connector"
Answer
Issue:
Users attempting to synchronize files across services or platforms may encounter the error message "File is already synchronized using a different connector." This error indicates a conflict that prevents the synchronization process from proceeding because the file in question is already linked to another connector.
Cause:
This error occurs when the user tries to sync a file that has been previously synchronized or mapped with a different connector. When the system detects that the file is associated with another synchronization relationship, it halts the operation to prevent any potential data conflicts or duplication.
To resolve the issue and successfully synchronize the file:
- Locate the file that is causing the synchronization conflict.
- Unmap the file from the existing connection
