View a Response for a Closed Issue
  1. Open the new version of the transmittal.
  2. On the Response tab, scroll down to the Updated or new documents section and expand the row for the PDF containing the issue that was verified as resolved.
    Here you can see the number of open (unresolved or fixed) and closed (resolved) issues.
  3. Click View response.
    The PDF opens in the PDF Markup Service, this time only showing the open issues by default.
  4. If you want to see the closed issues on the PDF and in the issues list, click the Filter button at the top of the issues list and turn on the display of Closed issues.
