Sending Transmittals (ProjectWise Explorer)
To Create a Transmittal (ProjectWise Explorer)
To Add Recipients to a Transmittal Draft (ProjectWise Explorer)
To Add ProjectWise Documents to a Transmittal Draft (ProjectWise Explorer)
To Set Due Dates and Reminders for the Transmittal (ProjectWise Explorer)
To Open a Transmittal Draft (ProjectWise Explorer)
To Send a Transmittal Draft for Review (ProjectWise Explorer)
To Review a Transmittal Draft (ProjectWise Explorer)
To Delete a Transmittal Draft (ProjectWise Explorer)
To Issue a Transmittal (ProjectWise Explorer)
To Recall a Transmittal (ProjectWise Explorer)
To View Transmittal Responses (ProjectWise Explorer)
To Share a Transmittal with Other Internal Participants (ProjectWise Explorer)
To Manually Import Attachments to Transmittal Responses into the Work Area (ProjectWise Explorer)
To Unlock a Response (ProjectWise Explorer)
To View the History of a Transmittal (ProjectWise Explorer)
To Send Updated Documents in a New Version of the Original Transmittal (ProjectWise Explorer)
