To View the History of a Transmittal (ProjectWise Explorer)
- Expand the Deliverables Management node under your associated work area.
- Expand the Outgoing folder and select the Transmittals folder.
- Open the transmittal you want to view the history of.
- Click the Audit Trail tab.
