To Share a Transmittal with Other Internal Participants (ProjectWise Explorer)
- Expand the Deliverables Management node under your associated work area.
- Expand the Outgoing folder and select the Transmittals folder.
- Open a transmittal from the list.
- From the action menu, select Send link via email.
- In the Send link via email dialog, click Send to to select the internal participants you want to share the transmittal with, enter an optional comment in the Comment field, and click Send. The participants you select here will be remembered and pre-selected the next time you share a transmittal or submittal from this project in ProjectWise Explorer.
