This procedure assumes that an internal participant has sent you a transmittal draft to review. You can review the draft, make changes to the draft, reject the draft, or if you have the Issue package permission you can also issue the transmittal.
The Draft Rejection dialog opens.
An email notification is sent to the draft author informing them of the rejection. The draft is unlocked to the draft author who can now open the draft, make the necessary modifications, and send out it for review again or issue it.
