Set the date by which the recipient(s) of the transmittal who are required to acknowledge must acknowledge that they have received the transmittal.
| Option | Description |
| Days after issue | Select this option if you want the acknowledgement due date to be a specific number of days after the transmittal is issued, and then enter how many days after issue that should be. |
| Fixed date | Select this option if you want to set a fixed date by which you need to receive acknowledgements, and then click in the field and select the date from the calendar. |
| Send reminder | Optionally, enter the number of days prior to the acknowledgement due date that you want a reminder to be sent to the recipients. |
When a particular recipient's acknowledgement is overdue, both the issuer and the recipient will receive an email notification about it.
| Days after issue | Select this option if you want the response due date to be a specific number of days after the transmittal is issued, and then enter how many days after issue that should be. |
| Fixed date | Select this option if you want to set a fixed date by which you need to receive all responses, then click in the field and select the date from the calendar. |
| Send reminder | Optionally, enter the number of days prior to the response due date that you want a reminder to be sent to the recipients. |
When a particular recipient's response is overdue, both the issuer and the recipient will receive an email notification about it.
