| Draft type | Do this |
| Blank | Right-click the Deliverables Management node, the Draft folder, or the Outgoing folder, then select New Transmittal. |
| From template | Right-click a transmittal in either the Draft or Outgoing folder and select New Transmittal from this template. |
| Pre-populated with ProjectWise documents | Right-click the ProjectWise document(s) you want from anywhere in the datasource and select Send To > Deliverables Management.
In most cases, the Transmittal Draft dialog opens next for you to configure the transmittal.
If you are creating a transmittal by selecting ProjectWise documents, and the documents you have selected are not in a work area where ProjectWise Deliverables Management is enabled, then before the Transmittal Draft dialog opens, you are prompted to first select a work area in which ProjectWise Deliverables Management is enabled to store the transmittal.
Other team members will still see a record of it (name and ID) in their list of incoming submittals, but they will not be able to open it. The administrator and the transmittal author and issuer will always have access to it.
Purposes are defined by the administrator in the ProjectWise Deliverables Management portal.
When distribution rules are configured for the project, selecting a purpose filters the Distribution rules list to display only the distribution rules that are related to the selected purpose.
The selected distribution rule automatically adds pre-selected recipients with fixed acknowledge and response settings, sets the maximum response date and time for those recipients, and sets the required document attributes.
If the selected distribution rule also specifies any pre-selected additional reviewers for a given recipient, the additional reviewers do not appear on the Recipients tab. Instead, a note is added in the Details column on the Audit Trail tab, listing which additional reviewers were selected to send responses to which original recipient.
Distribution rules exist in the project when the administrator configures the document distribution matrix in the ProjectWise Deliverables Management portal. If there is no document distribution matrix, then there will be no distribution rules to choose from in this list.
Cover letters are uploaded to the project and managed by the administrator in the ProjectWise Deliverables Management portal.
Classification labels are used to categorize transmittals, submittals, RFI's, and general correspondences into the parts of the project they relate to.
They can also be used in conjunction with storage settings to control where in the work area the related incoming documents are imported into.
Classification labels are completely customizable in each project and are defined by the administrator in the portal settings. The administrator can also decide whether to make assigning a classification required or optional. If the Classification list is not present at all, it means the administrator has not defined any classification labels for this project.
