Error Code 320 HEAD: crown radius not covered by code §UG-32.. message asppears in AutoPIPE Vessel
Problem:
When revieing the output report of a particular model analyzed per ASME VIII div 1, the following was observed.
1. In the "Summary of Errors and Warnings" subsection of the report:
320          HEAD: crown radius (xxx in) not covered by code §UG-32 (j) (diameter=xxx in , thickness=xxx in).
These messages are in direct conflict. Which is correct?
Take a moment to look up in the respective code the section on ASME VIII Div 1, section "UG-32 FORMED HEADS, AND SECTIONS, PRESSURE ON CONCAVE SIDE".
Read thru the section looking for a clause that talks about the relationship between crown radius to the outside diameter of the skirt of the head.
AS of AutoPIPE Vessel 45.00.02.004. there is no check in the report or no red text to indicate a problem when the clause is not true, just an error message shown above.
A new bug (1533905) has been logged and will be added to a future version of the program.
Question:
Given the error message above, and with the understanding that the shallow crown may violate the ASME VIII Div 1, section UG-32 clause, could it be acceptable if the stresses are low? Will the maximum stress currently calculated by the application in the crown be correct regardless of violating the clause above?
Answer:
Bentley is unable to assume this responsibility in answering these questions, as it does not align with our role. We recommend considering the following options:
1. Request and official written response from ASME committee to agree with your point of view.
Or
2. Designate a different code in AutoPIPE Vessel which does not have the same limitation, to check the stress.
Warning Messages, Unregistered Messages, Error Messages, or Application Crash issues
AutoPIPE Vessel
