| Product(s): | ProStructures (ProConcrete) |
| Version(s): | CONNECT Edition (10.XX.00.XX) & 2023+ |
| Area: | Concrete Partlist |
| Subarea: | Sorting |
| Original Author: | Vyanktesh Nama, Bentley Global Technical Support |
This KB shows how to sort rebars in Bar Bending Schedule with Barmarks.
1. Open your model and position the objects.
2. Open the Create Concrete Partlist tool located at Data/Reporting > Reporting > Create Concrete Partlist.
3. In the Partlist Creation dialog, enter the required name for the MDB file and click on the OK button and then select Choose All.
4. Select your desire LST file in the Partlist Print dialog and click on the Edit partlist Definition button.
5. Select the partlist main body then in the Properties under the Data section, change the Sort Order to Barmark, Bar Size, Length and save the LST file.
6. In Partlist Print dialog, click on the Preview Partlist button.
7. Select your desire print option and click on the Start button.
8. Now, you can see the sorting order of the rebars according to the barmarks in bar bending schedule.
In this way, we can sort rebars in Bar Bending Schedule with Barmarks.
