Tutorial Video : General
This page contains the description of and links to the general tutorial videos for STAAD Foundation Advanced 20xx.
Load Envelopes: In STAAD Foundation Advanced, load envelopes instruct the program which load cases/combinations to use for analysis or design. In this video, you will learn how to define the service load envelope and ultimate load envelope. You will also learn how to create custom load envelopes.
https://youtu.be/D2ZgNDWqD5M
Post Analysis Criteria: In STAAD Foundation Advanced, the Post Analysis Criteria (PAC) is used to instruct the program which serviceability limit state (i.e. sliding, overturning, and soil bearing pressure), to include in the post analysis check for the mat foundation. In this video, you will learn how to instruct the program which post analysis checks to perform.
https://youtu.be/N2n-0Cf6Dg4
