| Product(s): | AutoPIPE Vessel | ||
| Version(s): | 45.00.02.004 | ||
| Area: | Calculation | ||
How allowable stresses are being calculated for CODAP in AutoPIPE Vessel ?
AutoPIPE Vessel calculates Allowable stresses for CODAP as per code Table GA4.6.1-1.
These formulas can be seen in the Report>Allowable stresses and safety factors.
Input Data:
Also if required user can change the safety factors from Vessel Properties<Design Conditions<Design Values<User Defined<Edit.
For Example,
