This page contains the Validation Problems that have been created for Combined Footing design as per Indian design code IS 456:2000. The Results of STAAD Foundation Advanced program are compared with the hand calculated Values. The validation document includes the STAAD, SFA files and Validation document.
Problem 1
This problem demonstrates the procedure used by SFA for performing the calculation of the area of tension reinforcement required for a bending moment at design station.
Problem 2
This problem demonstrates the procedure used by SFA for performing the calculation of moment capacity of the section for reinforcement provided at section.
