Supported Connections List
Below devices and sensors are integrated into the iTwin IoT platform. These devices and sensors are added as Connections directly in the application or through a file transfer process.
Cell or Radio Connections added directly to iTwin IoT Application
Geokon Geonet 8800 Series Logger
Geokon Geonet 8900 Series Logger
Sensemetrics Strand VW4
Worldsensing Thread
Worldsensing Loadsensing G6 Gateway
API Connections
Ackcio Analog Communication Beam Node
Ackcio Digital Beam Tiltmeter
Ackcio Vibrating Wire Beam Node
Ackcio MDT MPBX
Instantel Thor Micromate
Move Solutions Accelerometer SHM
Move Solutions Analog Communication Node
Move Solutions Deck Dynamic Displacement Device
Move Solutions Digital Communication Node
Move Solutions Gateway
Move Solutions Single Channel Node
Move Solutions Wireless Tilt Beam
Move Solutions Wireless Triaxial Tiltmeter
Move Solutions Wireless Vibrometer
Viotel Accelerometer
Viotel Tiltmeter
Worldsensing Analog 4-channel LS-G6-ANALOG-4
Worldsensing Digital Logger LS-G6-DIG-2
Worldsensing Worldsensing Laser Distance Meter LS-G6-LASER
Worldsensing Tilt Meter LS-G6-LAS-TIL90
Worldsensing Tilt Meter LS-TIL90-X
Worldsensing Tilt Meter LS-G6-TIL90-I
Worldsensing Vibrating Wire 5-Channel LS-G6-VW
FTP Connections
Senceive Tiltmeter
Trimble T4D Survey Data
Other Connection Types
Kinemetrics ETNA2 Accelerograph
Leica Spider GNSS Data
Leica GeoMos Survey Data
