| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version |
Sep. 2024 23.00.01.367 |
I need to override stress intensification factors at all fittings, and I've done that by inserting User SIFs. When I study analysis results, bends and reducers appear as I intend, but tees do not. I'm not even sure where the tees are getting their SIF because they don't match what is in the 'review component data' grid either. I've also tried unreinforced type tees automatic SIFs and "other" type with user entry in the grid, but that doesn't change anything. How do I get my SIF values into code calculations for tees and where is autopipe getting these SIF values otherwise if it's not using my override?
Let me explain you how this functionality works:
Basically, there are two scenarios':
Question.
IF tee type was changed to "welding" (sketch 2.1 of B31J) give the same effect as the elbow then, in that it keeps my user-defined SIF?
Answer.
As per the statement in B31J Gen Note d. "the components of sketches 2.1 through 2.6 the direction sustained stress or moment multiplier can be conservative taken smaller of the 3 conditions." Refer the screenshot from Help AutoPIPE given below:
So, if you change the tee type the effect will be same. Because sketches from 2.1 through 2.6 is covered under this note.
Question.
How to override SIF at a node point
Answer.
See KB article here.
