| Setting | Description |
| System Requirements |
LumenRT is a 64-bit application, designed for WindowsR 64 bit Win 10 operating systems. LumenRT is either CPU or GPU intensive depending on the task being performed. The pre-processing phase is CPU intensive while the navigation/viewing process is GPU intensive. Performance of the software is directly related to the power of the system running it. LumenRT is optimized to make the best of all the processors/cores on your system. The power of your video board directly impacts the frame-rate during real-time 3D play-back. |
| Supported LumenRT Export Plugin Applications |
| Processing/Authoring Platform Requirements |
This is the machine configuration on which you will author scenes and animations inside the LumenRT LiveCube.
| Processing/Authoring Platform Requirements (Ray Traced Version/RTX) |
Note: Raytracing mode will only work on DXR capable graphics cards.
| Navigation/Viewing Platform Requirements |
This is the machine configuration on which you or your client will navigate and explore published LumenRT LiveCubes. The more complex your model is, the more graphic power it will require:
