Sharing
Sharing
The share feature is part of the Embed API component and can be freely used if it is installed. It can be used to publicly share content for a given duration.
The sharing options allows users to quickly share a specific dashboard or dashboard component with another user. When sharing an item in VDV the user receives a custom URL that can be shared with anyone. The receiving user does not need to login to VDV to view the shared URL.
Dashboard share
Whole dashboards can be shared by opening the sidebar and click the button to share the dashboard.
A screenshot of a graphDescription automatically generated
Dashboard Widget share
Individual widget can be shared by hover over it and clicking on the icon to share the widget.
New share
Clicking the share icon opens the New Share dialog. Name is automatically set on the same name as the content being shared with options to specify:
Clicking Save will generate and show a link to open the share.
Edit share
Clicking the share icon on an already shared content will bring up the edit dialog. It has the same options as the New share dialog but also shows the current share link.
The share link will be regenerated if the share has expired.
My shares
Under the User Profile a list of all Shares can be accessed.
It is possible to edit previously created shares, either to add a new description or to renew their time duration. It is also possible to delete shares.
The icon is shown if the share has expired.
