| Version | PLAXIS 2D PLAXIS 3D |
| Date created | 20 September 2024 |
| Date modified | 20 September 2024 |
| Original author | Richard WITASSE - Principal Application Engineer |
| Keywords | PLAXIS 2D, PLAXIS 3D, Rock, Field Stress, K0-procedure, Circular Tunnel, Shotcrete |
The aim of this exercise is to illustrate two fundamental techniques in defining in-situ stresses for a rock mass respectively the K0-procedure and the field stress to represent an initial stress situation defined as:
where,
for the analysis of a circular tunnel excavation at a depth of 500 m in a uniform rock mass characterized by γ = 25 kN.m-3, K0,H = 1.2 and K0,h = 0.8. In this example, two PLAXIS models will be built up for the analysis of the tunnel excavation process followed by the activation of a 20 cm thickness shotcrete lining each model using a different initial stress definition technique.
