Here you will be able to find answers to why an Export failed and how to fix it.
The user who initiated the IFC Export does not have permission to write a file to the location specified for the generated IFC model. To resolve this, please ensure that that user has write access to the location specified to place the IFC model.
Steps to assign Write permission :
The user who initiated the export does not have read
permission for the iModel being used as the source for the IFC Export. To resolve this, please assign the user the appropriate read
permission.
Steps to assign Read permission :
Export to IFC failed because the iModel has more than 1.5 million elements. If the entire iModel has more than 1.5 million elements, a saved view should be used to define content that contains less than 1.5 million elements. Please use the saved view with less than 1.5 million elements for the IFC Export.
The export to IFC failed because there is an error in the provided user defined schema mapping file. Please ensure that the user defined schema mapping file matches the standard schema for mapping files.
For reference, the default mapping file for IFC Exports can be found here: Default Mapping File for IFC Exports
Export to IFC failed as the iModel was not found. The iModel being exported to IFC may no longer exist or is inaccessible by the user who started the export.
Possible Solutions:
The Export to IFC was unable to find the user defined mapping JSON file. The user defined mapping JSON file may no longer exist or is inaccessible by the user who started the export.
