| Draft type | Do this |
| Blank | Click the New menu and select New RFI.
| From template | Click the check box next to an RFI on either the Outgoing or Draft tab and select Use as a template.
The RFI draft form opens.
The Add recipient dialog opens.
You can use this dialog to select any one current internal or external participant to be the main recipient of the RFI.
You can filter the dialog to show only internal participants, only external participants, or both internal and external participants.
You can also use this dialog to invite new external participants to the project. Once invited, you can immediately add any one of the newly invited persons to be the recipient of the RFI (you do not have to wait for them to accept the invitation in order to issue the RFI).
You can only add one participant to the To field, but that person will have the opportunity to forward the RFI to another participant if needed (for example, if the RFI was sent to the wrong person, the recipient can forward it to the correct person).
To add a current external or internal participant:
To invite and add a new external participant:
The Invite external participant dialog opens.
A default subject is provided, which you can keep or change as needed.
An invitation is sent to the person, and they are added to the external participants list.
You can add as many current external and internal participants to the CC field as you need, you just cannot add a participant to the CC field if they are already added to the To field.
Classification labels are used to categorize transmittals, submittals, RFI's, and general correspondences into the parts of the project they relate to.
Classification labels are completely customizable in each project and are defined by the administrator in the portal settings. The administrator can also decide whether to make assigning a classification required or optional. If the Classification list is not present at all, it means the administrator has not defined any classification labels for this project.
The name of the person creating the RFI is supplied by default, but you can enter anybody's name, or even leave it blank.
The data and time you began creating the RFI is supplied by default, but you can change the date and time or even leave it blank.
Question attributes are defined by the administrator in the portal settings, and the administrator decides whether they are required or optional. It is also possible that your project does not contain any additional question attributes.
The following are the default RFI question attributes:
If there is a Suggested Impact Assessment attribute, then for each value you select, a Justification field opens where you can explain why you selected that value. For example, if you select Cost, you can provide a reason why you think cost might have an impact. Also, keep in mind that when selecting a value for Suggested Impact Assessment, the user who responds to this RFI will be presented with a corresponding Final Impact Assessment attribute. So if you select Cost for the Suggested Impact Assessment, then the responder can provide a Cost justification when they reply with their Final Impact Assessment.
If the project is associated with an AssetWise community, then you will see these additional attributes, which you can add values for:
For both due dates, you can either set a specific due date, or you can make the due date a certain number of days after the RFI was issued. You can also specify how many days (if any) before the due date that a reminder email will be sent to the recipient.
