Resetting User Credentials in PowerBi
Applicable App:
OpenGround Connector for PowerBi
Common Causes/Issues:
When trying to sync reports to OpenGround you are recieving error messages regarding permissions.
Solution Overview:
Reset your user credentials forcing PowerBi through the login process again.
Tactical Rundown:
Step 1
Open the Data Source Settings window. Click the bottom half of Transform Data on the Home Ribbon in PowerBi.
Select Data Source Settings from the Dropdown
Step 2
Edit the permissons of all OpenGround Sources.
Clicking Edit a second time opens the login window to refresh the credentials.
Step 3
Sign in again to refresh the credentials
