The ProStructures Product team is pleased to announce the availability of ProStructures 2024 (24.00.00.37) through the Bentley CONNECT Center, Software Downloads portal, or the desktop CONNECTION Client.
This version incorporates many user-requested fixes and enhancements. It also includes updates from MicroStation 2024.
What's New Highlights for ProStructures 2024
1. General Updates:
- Rebranding from ProStructures 2023 on to ProStructures 2024
Rebranding ProStructures 2023 to ProStructures 2024 results in several changes to the default installation directories, registry entries, executables and many other aspects of the application. References to '2023' were replaced with '2024' which refers to the current year. The ProStructures 2024 rebranding does not impact or change the feature set available in the product and is both the next update release and successor to ProStructures 2023. ProStructures Update 7.2 CE, ProStructures 2023 and ProStructures 2024 can coexist on the same computer, please refer to the side-by-side installation wiki.
- Integrated MicroStation 2024
It includes updates from MicroStation 2024
2. Installer Update:
Side-by-side Installation allows you to adopt ProStructures 2024 without upgrading your current installation of ProStructures 2023 or any previous version. For more information regarding configurations, please refer to refer the Side-by-side Installation wiki.
**If you already have a previous version of ProStructures on your machine, ProStructures 2024 will install as a separate application. **
3. Usability and Productivity Enhancements:
Usability and the overall user experience in ProStructures is a key focus for our team. The following improvements were implemented:
- Inclusion of BS 8666-2020 Rebar code
The BS 8666:2020 is the updated British Standard for the scheduling, dimensioning, bending, and cutting of steel reinforcement for concrete. It includes new shape codes and guidelines that align with the latest construction practices and Eurocode. This update ensures that rebar shapes are managed more efficiently and accurately according to the new rules and standards.
- Improved handling of unmanaged Rebar Shapes
Improvements have been made for handling the unmanaged Rebar Shapes for ACI rebar code especially for Shape 11, Shape 17, S11, S12, T13 and T14.
Update via CONNECTION Client:
If you have any earlier version of ProStructures already installed on your computer, you can incrementally download and install ProStructures 2024 from the CONNECTION Client, then ProStructures 2024 will be advertised as an update from the CONNECTION Client. However, it will NOT replace any earlier versions of the product and install it as a separate instance of ProStructures with the root directories C:\Program Files\Bentley\ProStructures 2024 and C:\ProgramData\Bentley\ProStructures 2024.
Sign-in to the CONNECTION Client to view and apply your application updates. If needed, please refer to the CONNECTION Client help for more information on installing the update.
Get ProStructures 2024:
- Open https://softwaredownloads.bentley.com/en/ProductDetails/2270 in any browser and sign in.
- Click Download to download ProStructures 2024 x64 version 24.00.00.37.
Note: Important installation requirements and notices are found in the ReadMe .
