The following table lists all builds of STAAD.Pro that have been released since STAAD.Pro V8i in 2008. Note that some builds were only released for commercial users and some only for QA&R subscribers.
| Description | Version | Date | Commercial | QA&R |
| STAAD.Pro 2025, minor 1 | 25.00.01.424 | 3 December 2025 | þ | þ |
| STAAD.Pro 2025, major | 25.00.00.539 | 09 July 2025 | þ | |
| STAAD.Pro 2024, minor 2 | 24.00.02.354 | 31 January 2025 | þ | þ |
| STAAD.Pro 2024, major | 24.00.00.577 | 08 August 2024 | þ | |
| STAAD.Pro 2023, minor 3 | 23.00.03.025 | 07 February 2024 | þ | þ |
| STAAD.Pro 2023, minor 2 | 23.00.02.361 | 15 December 2023 | þ | |
| STAAD.Pro 2023, minor 1 | 23.00.01.025 | 26 July 2023 | þ | |
| STAAD.Pro 2023, major | 23.00.00.345 | 30 June 2023 | þ | |
| CE V22 Update 12 | 22.12.00.142 | 08 November 2022 | þ | |
| CE V22 Update 11 | 22.11.00.156 | 22 August 2022 | þ | |
| CE V22 Update 10 | 22.10.00.180 | 24 June 2022 | þ | |
| CE V22 Update 10 | 22.10.00.153 | 07 April 2022 | þ | |
| CE V22 Update 9 | 22.09.00.115 | 28 January 2022 | þ | |
| CE V22 Update 8 | 22.08.00.175 | 04 November 2021 | þ | |
| CE V22 Update 7 | 22.07.00.160 | 22 July 2021 | þ | |
| CE V22 Update 6 | 22.06.00.138 | 01 April 2021 | þ | |
| CE V22 Update 5 | 22.05.00.148 | 12 January 2021 | þ | |
| CE V22 Update 5 | 22.05.00.131 | 19 October 2020 | þ | |
| CE V22 Update 4 | 22.04.00.40 | 04 May 2020 | þ | |
| CE V22 Update 3 | 22.03.00.28 | 17 January 2020 | þ | |
| CE V22 Update 2 | 22.02.00.026 | 17 September 2019 | þ | |
| CE V22, Update1 | 22.01.00.39 | 20 May 2019 | þ | |
| CE V22 Update 1 | 22.01.00.38 | 20 May 2019 | þ | |
| CE V22 | 22.00.00.15 | 21 December 2018 | þ | |
| CONNECT Edition Update 3 | 21.03.00.146 | 01 October 2018 | þ | |
| CONNECT Edition Update 2 | 21.00.02.44 | 29 May 2018 | þ | |
| CONNECT Edition Update 2 | 21.00.02.43 | 29 May 2018 | þ | |
| CONNECT Edition Update 2 | 21.00.02.40 | 10 May 2018 | þ | |
| CONNECT Edition Update 2 | 21.00.02.32 | 22 March 2018 | þ | |
| CONNECT Edition Update 2 | 21.00.02.30 | 08 March 2018 | þ | |
| CONNECT Edition Update 1 | 21.00.01.12 | 10 November 2017 | þ | |
| CONNECT Edition | 21.00.00.57 | 04 August 2017 | þ | |
| V8i SELECT series 6, SP4 | 20.07.11.90 | 13 April 2017 | þ | |
| V8i SELECT series 6, SP3 | 20.07.11.82 | 11 July 2016 | þ | |
| V8i SELECT series 6, SP2 | 20.07.11.70 | 21 March 2016 | þ | |
| V8i SELECT series 6 | 20.07.11.50 | 03 December 2015 | þ | |
| V8i SELECT series 6 | 20.07.11.45 | 30 September 2015 | þ | |
| V8i SELECT series 6 | 20.07.11.33 | 28 June 2015 | þ | |
| V8i SELECT series 5 | 20.07.10.66 | 27 December 2014 | þ | |
| V8i SELECT series 5 | 20.07.10.65 | 02 November 2014 | þ | |
| V8i SELECT series 5 | 20.07.10.64 | 21 July 2014 | þ | |
| V8i SELECT series 5 | 20.07.10.41 | 25 November 2013 | þ | |
| V8i SELECT series 4 | 20.07.09.31 | 10 March 2013 | þ | |
| V8i SELECT series 4 | 20.07.09.21 | 23 December 2012 | þ | |
| V8i SELECT series 4 | 20.07.09.20 | 03 December 2012 | þ | |
| V8i SELECT series 4 | 20.07.09.11 | 05 August 2012 | þ | |
| V8i SELECT series 3 | 20.07.08.22 | 20 May 2012 | þ | |
| V8i SELECT series 3 | 20.07.08.20 | 13 September 2011 | þ | |
| V8i SELECT Series 2 | 20.07.07.32 | 05 March 2011 | þ | |
| V8i SELECT Series 2 | 20.07.07.19 | 13 October 2010 | þ | |
| V8i SELECT Series 1 | 20.07.06.35 | 05 June 2010 | þ | |
| V8i SELECT Series 1 | 20.07.06.34 | 23 March 2009 | þ | |
| V8i SELECT Series 1 | 20.07.06.23 | 23 December 2009 | þ | |
| V8i, Build 05 | 20.07.05.15 | 01 June 2009 | þ | |
| V8i | 20.07.04.12 | 30 October 2008 | þ | þ |
