Q3. What are the meanings of the error messages on WRC 107 / 297 / 537 ?
Product(s): AutoPIPE Vessel
Version(s): ALL
Area: General
Date Logged
& Current Version
August 2024
45.00.02.004
Problem:
Generally we face following errors in the WRC calculations,
998        LOCAL LOADS (A): beyond curve boundaries (WRC 537 cannot be applied).
  52        LOCAL LOADS: Beyond the Scope of application of WRC (load mark D).
  50        LOCAL LOADS: Stress(es) exceeds allowable (load mark D).
Above errors gives you basic reason behind the error. For detailed information you have to refer report and code to understand the actual reason of the error.
AutoPIPE Vessel
WRC 107/537/297
Bentley LEARN Server
