| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version |
August 2024 45.00.02.004 |
WRC 537 include extrapolated curves. Does APV consider data from these curves?
AutoPIPE Vessel does cover the extrapolated data given in the code. Please note that equations and extrapolated curves are given in the code and can be used.
We perform the calculations using code equations and compare the data with original curve given in code.
When we use the extrapolated data we give note for understanding.
For example,
