| Version(s): | ALL |
| Area: | General |
| Date Logged & Current Version |
August 2024 45.00.02.004 |
Why AutoPIPE Vessel uses SR-X curves when using WRC107 calculation for a nozzle on a spherical shell?
You need to select WRC 107/297 (or 537/297) to consider a hollow attachment (Nozzle) in calculations.
Select WRC 107 (or 537) to consider a solid attachment.
When you consider WRC 107/297, AutoPIPE Vessel uses SP-X and SM-X curves in calculation.
