Applies To | |||
Product(s): | STAAD.Pro | ||
Version(s): | All | ||
Environment: | N/A | ||
Area: | OpenSTAAD | ||
Subarea: | View | ||
Original Author: | Shreyanka Bhattacharjee, Bentley Technical Support Group | ||
Problem Description:
How to export saved view using OpenSTAAD functions (VBA)
Along with that, the functions mentioned below can be used to open the view and resize and reposition active window to capture the image.
These functions are available from STAAD.Pro Advanced 2024 - Version 24.00.00.577
Parameter:
The details of the Parameter can be found in OpenSTAAD Documentation under Help option
Sample VBA Syntax:
Sub Export_View()
Dim varReturnVal As Long
Dim nName As String
Dim windowOptions As Boolean
Dim count As Long
Dim xWindow As Long
Dim yWindow As Long
Dim vnName(2) As String
Dim xTop As Long
Dim yTop As Long
Set objOpenStaad = GetObject(, "StaadPro.OpenSTAAD")
vnName(0) = "view1"
vnName(1) = "view2"
vnName(2) = "view3"
xTop = 0
yTop = 0
windowOptions = True
For i = 0 To 2
varReturnVal = objOpenStaad.View.OpenView(vnName(i), windowOptions)
ID = 1
objOpenStaad.View.SetActiveWindow ID
objOpenStaad.View.GetApplicationDesktopSize xWindow, yWindow
varReturnVal = objOpenStaad.View.SetWindowPosition(xTop, yTop, xWindow, yWindow)
Application.Wait (Now + TimeValue("0:00:01"))
fileLoc = "D:\Export View" 'Change this location as per the requirement
Filename = "Image" & i + 1
FileType = 1 '0 = bmp, 1 = jpg, 2 = tga, 3 = tif
overWrite = True
objOpenStaad.View.ExportView fileLoc, Filename, FileType, overWrite
Next i
End Sub
Output:
Please refer to the article below to save view using openSTAAD
