Printing the Map Floor/Fence with surface loads crashes Steel Beam
Product: RAM Structural System
First Affected Version: 2024
Fixed in Version: 24.00.01
Area: Reports
Issue #: 1493206
Problem Description
Printing the screen using Report - Map Floor or Map Fence when including surface loads will cause the program to crash. THe underlying cause is due to having a space in the path to the \Reports directory.
Work Around
Edit the ramis.ini file in this location: C:\ProgramData\Bentley\Engineering\RAM Structural System
Change the line that says reports=C:\ProgramData\Bentley\Engineering\RAM Structural System\Reports to use a path that has no spaces in it, for example reports=C:\temp, and save the changes to the ramis.ini file. Make sure the Folder path entered actually exists, or create a new folder in that exact location.
Note, you may want to restore the original reports path after installing the 2024 minor version update. You can backup the ramis.ini file first, or simply remove that line before installing he new version.
Alternatively, use File - Print with loads displayed (using Options - Set Show Options - Miscellaneous) while in RAM Modeler.
Fixed for version 24.00.01.
