Export to CMYK EPS (Contour Cut)
Product:
OpenRoad SignCAD 2024
Version:
24.00.00.56
Area:
How-to
Original Author:
The instructions and video below show how-to Export to CMYK EPS for contour cutting.
Step 1:  Select the file, sign or other element (arrow, graphic, etc.) to export.
Step 2:  Pick the File tab to go to the Backstage and pick Export. Select the CMYK EPS or Selected CMYK EPS option.
Step 3:  In the Export to CMYK EPS File dialog, press the button with the three dots to the right of the EPS File Name, enter a File name and press Save.
Step 4: Check the Contour Cut box and press Export to generate the EPS file.
Step 5: Bring the saved EPS file into your cutter/plotter software to cut the sign.
