How to Zoom to Element(s) selected in the Properties dialog
  Product: MicroStation
  Version: CONNECT Edition
  Environment: N\A
  Area: Base Geometry
  Subarea: N\A
How can you zoom to selected Element(s) from the Properties Dialog.
Having selected the element(s) in the design and opened the Properties dialog, the selected element(s) can zoomed to using the Right Mouse Button menu
1. In the Properties dialog, expand the tree of Selected Elements and select the Element(s) you wish to zoom too.
2. Right Mouse click on the Selected element withing the Properties dialog and select Zoom from pop up menu.
Note. Multiple Elements can be Selected by holding down the CTRL key down and selecting them within the Properties dialog. In this instance when selecting Zoom the View is zoomed to include all selected elements.
  Original Author: Carl Myhill
