Client Server Archive
Client Server is an online newsletter for our SELECT users. This online resource is filled with the latest technical news and information for our Bentley SELECT subscribers. See current articles here or search the wiki or look below for archived ones.
2010
Using MicroStation Plot Driver to create and convert Printer Driver Configuration files [CS] 28 April 2010
Utilizing the focus.rsc file in Bentley Communications products [CS] 15 April 2010
2009
Understanding Component Manager in AutoPLANTs SpecGen 08 [CS] December 2009
Upgrading to SELECTserver 08 11 series [CS] 01 October 2009
Reference Loads An Introduction [CS] 11 September 2009
The New Merge Tool in Descartes [CS] 11 August 2009
Migrating Legacy Data To promis e V8i[CS] 15 July 2009
SELECT Server 08 11 Series [CS] 15 July 2009
Answers for the Levelly Challenged [CS] 14 July 2009
Specification Selection Error [CS] 28 January 2009
Conceptual Design and MicroStation [CS] 21 January 2009
How To Contact Bentley Technical Support [CS] 15 January 2009
2008
RAM CADstudio Column Schedules 27 February 2008
Enhancements And Changes To MicroStation XM Printing In Versions 08.09.03.xx And 08.09.04.xx 27 February 2008
Repairing Missing Component Data In AutoPLANT 3D 31 March 2008
Bringing a WaterGEMS XM Model into ArcGIS - Tips & Tricks 31 July 2008
Creating PDF Files Containing Project Explorer Links 29 September 2008
Using CADscript's MapIndex Tool 29 September 2008
2007
Using The Replace Cells Tool 07 February 2007
Working With Dimension Styles In DWG Workmode 08 May 2007
Recovering Corrupt DGN And DWG Files 12 June 2007
Enhanced Selection Set Features From WaterCAD And WaterGEMS 18 June 2007
Frequently Asked Questions About Bentley Building Electrical Systems 29 August 2007
Attaching Displaying Raster Images In MicroStation 03 October 2007
InterPlot products are now part of the ProjectWise family What does this mean to today's InterPlot user? 28 November 2007
Using VBA to Programmatically Import a VBA Project's Components and References 05 December 2007
2006
Digitizing Configuration Using Wintab 06 January 2006
Update Levels In InterPlot Plot Set And Parameter Files 10 February 2006
Network Installation Guide For Haestad Solutions Products 03 March 2006
Using The Batch Process Utility In MicroStation V8 27 March 2006
Setting Up Fire Flow Analysis In WaterCAD And WaterGEMS 05 June 2006
Exporting DGN Data To ESRI Shapefile Format With MicroStation GeoGraphics 07 August 2006
Navigating The Input Grids In Bentley AutoPIPE 2004 14 August 2006
Efficient Modeling With Features In MicroStation V8 14 August 2006
Shapefile Connections In WaterCAD WaterGEMS 14 August 2006
MicroStation Exception Log Primer 30 October 2006
2005
Using MicroStation Tags 12 January 2005
Trouble Shooting AutoIsogen For AutoPLANT Plant Design Workgroup 2004 Edition 03 February 2005
Plot Orientation On Roll-Fed Plotters 14 February 2005
Configuring ProjectWise V8 2004 Edition Caching Server 24 March 2005
Using The AutoCAD 2005 Compatibility Tool 22 April 2005
Creating Zoom-Independent Symbols 16 May 2005
Using LandXML to Transfer Design Data between MXROAD, InRoads, and GEOPAK 23 May 2005
PDF Print Driver 31 May 2005
Selecting the Correct Database for Your Bentley Instrumentation & Wiring Project Environment 13 June 2005
Setting Linestyle Scale In MicroStation V8 20 June 2005
Interplot Offline Raster Driver Pack 30 June 2005
Getting Started With The Standards Checker 22 July 2005
Understanding Component Preferences In Bentley AutoPLANT 2004 Edition 25 October 2005
2004
Re-Mapping ByLevel Color When Saving To DWG 02 January 2004
Uploading SELECTserver Usage Logs 20 January 2004
Level Enhancement Examples For MicroStation V8 2004 Edition 09 February 2004
Extend GeoGraphics Database From Previous Versions To MicroStation V8 17 February 2004
Upgrading Your HMR Raster Attachments To MicroStation V8 08 March 2004
MX To MicroStation Configuration Options 22 March 2004
Title Block Integration For MicroStation 30 March 2004
Importing Shape Files Into MicroStation GeoGraphics 12 April 2004
New From Bentley SELECT This Month 27 April 2004
Reading Elements From A Microsoft Access Database With VBA 03 May 2004
Extracting MicroStation Tag Data To A JSM File 18 May 2004
Annotation Enhancements In MicroStation TriForma 2004 Edition 01 June 2004
Using The AutoSave Features In MicroStation V8 21 June 2004
Introducing Segment3D Methods In MicroStation V8 2004 Edition 28 June 2004
Using Parameter Sets With MicroStation V8 2004 Edition 14 July 2004
InRoads Survey and PowerSurvey, 2004 Edition New Tools Streamline Workflows 28 July 2004
Debugging Native Code MDL Applications 09 August 2004
Configuration Variables For Bentley GEOPAK 2004 Edition Products 20 August 2004
ProjectWise Web Explorer Lite Enhancements And Improvements 07 September 2004
Digital InterPlot Design Script Extensions For ProjectWise Components 13 September 2004
The Equation Icon In MicroStation V8 2004 Edition 21 September 2004
Using Chinese Fonts In MicroStation 11 October 2004
Unleashing The Power Of The Desktop Within MicroStation V8.5 18 October 2004
Choosing The Right Project Mode And Database For Your AutoPLANT 2004 Project 25 October 2004
Using Bentley Navigator To Link Multiple Construction Events To One Schedule Activity 01 November 2004
Changes To Batch Print In MicroStation V8 2004 Edition 09 November 2004
MicroStation VBA Resources Revisited 15 November 2004
Haven't Upgraded to the MicroStation V8 Format Yet? 22 November 2004
Using VBA To Programmatically Export A VBA Project 02 December 2004
Enhancing Performance With ProjectWise File Caching 13 December 2004
Help For CAD Users Moving To MicroStation 20 December 2004
2003
Using ProjectWise Authentication Server In Active Directory Domain Model 06 January 2003
Working With Displayable Attributes 23 January 2003
Working With DWG Reference Files 03 February 2003
Printing Images From MicroStation V8 Raster Manager 10 February 2003
Analyzing Program Usage Data With The SELECTserver License Manager 17 February 2003
Clean Up Your Environment! 24 March 2003
Introducing Bentley's Service Request Manager 31 March 2003
2D or 3D Choice For Design 07 April 2003
Using InterPlot Organizer For Group Plot 14 April 2003
Using The Workspace Profiles Capability In Bentley ProjectWise 21 April 2003
How To Write A Recursive Routine In MicroStation VBA 05 May 2003
Using Named Groups In MicroStation V8.1 12 May 2003
A MicroStation VBA Example With Bentley ProjectWise 26 May 2003
Data Collection For Digital Terrain Models Understanding And Evaluating The Options 03 June 2003
Tips From The Knowledgebase From MicroStation On The Web 10 June 2003
Working With Levels In MicroStation VBA 25 June 2003
MicroStation Telco The Ideal Tool For Work Order Design 14 July 2003
Configuration Files In SELECTserver 21 July 2003
Your Solids Working Area, Global Origin, Working Units, and You 28 July 2003
Getting And Setting Elements Using Graphic Groups In VBA 04 August 2003
The Reference Preference Redux 11 August 2003
Modeling Valves Without Operators In PlantSpace Design Series V8.1 22 August 2003
Plotting White Element Based On File Format 29 August 2003
New Dimensioning Tools 16 September 2003
InterPlot Organizer Integration With Bentley ProjectWise 8.1 29 September 2003
Working Units Upgrading MicroStation GeoGraphics Data To The MicroStation V8 File Format 06 October 2003
Are You New to Bentley View? 15 October 2003
Using The 400 Grad Angle System In MicroStation V8 27 October 2003
Exporting, Editing, and Importing an Environment Via a Script File 04 November 2003
Plotting To A Printer With Non-Sysprinter Plotter Driver Files 11 November 2003
Things To Know For The Surface Model Beginner 14 November 2003
Virtual Training From The Bentley Institute Good Option For Busy Schedules 25 November 2003
Raster Attachment Update In I RAS B V8 01 December 2003
Producing Consistent Line Thickness With InterPlot 15 December 2003
New From SELECTservices Online This Month 19 December 2003
Exploring The Possibilities Of Properties 19 December 2003
2002
Using The New License Reporting Features In SELECTserver 7.3 12 February 2002
Unleashing Database Linkages In MicroStation 13 February 2002
Determining Coordinates Necessary For Design File Setup With MicroStation GeoCoordinator 30 April 2002
Unleash A Workspace Wizard Automating Workspace Creation With MicroStation V8 And VBA 30 April 2002
Project Sharing In MicroStation GeoGraphics ISpatial Edition 30 April 2002
ECW Image Extension For MicroStation V8 Released 30 April 2002
Converting MicroStation TriForma Datasets From MicroStation J To MicroStation V8 30 May 2002
Retrofitting Existing Data With InRoads Creating Linear DTM Features From Existing Survey Data 30 May 2002
Creating Bridge Typicals With InRoads Bridge And MicroStation V8 Via 3D Extraction 10 June 2002
The Power Of OLE In MicroStation V8 18 June 2002
Configuration Variable Processing 24 June 2002
Features And Benefits Of The InterPlot Plotting Solution 01 July 2002
Opening And Saving DWG Files In MicroStation V8 15 July 2002
MicroStation V8 VBA Programming Resources 22 July 2002
The Advantages of MicroStation V8 for Bentley's Civil Engineering Users 29 July 2002
The Ultimate Raster Border Working With Boundaries In MicroStation I RAS B 05 August 2002
Working With Design History In MicroStation V8 12 August 2002
Raster Manager Preferences Within The MicroStation V8 Workspace 26 August 2002
Scanning For MicroStation V8 Elements In VBA 30 August 2002
New Color Masks In MicroStation Descartes V8 09 September 2002
Advanced Design Review Capabilities For Your Entire Project Team 16 September 2002
Finding The Right Technical Support 23 September 2002
Text Substitution Enhancements To MicroStation V8 Pen Tables 30 September 2002
Launching VBA Applications As Initapps Or Dgnapps
Using The DWG Work Mode In MicroStation V8 14 October 2002
Using The Solids Working Area In MicroStation V8 21 October 2002
Controlling The Grid Orientation In MicroStation V8 25 October 2002
Portable Plan Set With Digital InterPlot 04 November 2002
Sharing Your Workspace 11 November 2002
The Power Of CSV 19 November 2002
SELECTservices Online Administrative Tools You Might Not Know About 25 November 2002
Unlocking IDesktop Integration 02 December 2002
Bypassing Port Problems In Windows 2000 And Windows XP 09 December 2002
Using Database Queries for PlantSpace P&ID Tagging 16 December 2002
