Files Saved down to V7 Format are enabled with Enhanced Precision
  Product(s): MicroStation
  Version(s): V8-V8i
  Environment:  N\A
  Area:  DGN
  Subarea:  Save
Files Saved down to V7 Format are enabled with Enhanced Precision.
A variable can disable this.
Files created in V8 are enabled with Enhanced Precision.
This capability was added around V7.1 <(>&<)> has been enabled in every version since.
V7.0 <(>&<)> below will not open these files <(>&<)> display the following error message:
Unable to Open Design File.
Product: MicroStation
Version: Varies
Area: Save as V7
Set/Define the following variable to remove enhanced precision from the V7 file:
Workspace > Configuration>MS_ENHANCEDPRECISION = 1
Note: Starting with MicroStation Update 17, V7 Workmode (Save in V7 format, V7 format file editing option) has been removed and this variable no longer affects MicroStation processes.
See the following information under the What's new in MicroStation's Help.
New and Changed in MicroStation CONNECT Edition Update 17 (bentley.com)
