Create Solid from Section Elements [VID]
  Product: MicroStation
  Version: V8, 2004, XM, V8i
  Environment: N\A
  Area: Solids
  Subarea: Legacy Solids
How to
Create a solid using section elements
Support Video Clip
www.youtube.com/watch
Steps
1. Use Loft Surface tool to create a B-spline surface that is transformed between section elements (lines, line strings, arcs, ellipses, complex chains, complex shapes, B-spline curves, or the edges of a surface).
2. Use Convert to Solid tool to create a solid from the lofted surface.
MicroStation Help - Loft Surface
Other language sources
  Original Author: Craig Calvin
