Cannot modify selection sets
  Product: MicroStation
  Version: V8, XM, V8i, CONNECT
  Environment: N\A
  Area: Selection
  Subarea: Sets
Cannot modify selection sets. (copy, move, rotate, delete, etc.)
Cannot use modify tools on a selection set. If a selection set is created, the tool is started, selection set is unselected or only the last element selected is modifying.
Steps to Reproduce
-Select a group of elements with selection window, Power Selector or
Select By Attributes
-Start a tool that will edit select sets (copy, move, Change Element
Attributes, etc.)
Result 1
The selection set will unselect.
Result 2
The selection set is still selected, however after finishing the
operation, only 1 of the elements are modified.
Selection lock is off.
There are 2 possible methods to enable selection lock.
MICROSTATION KEY-IN
Key-in: LOCK SELECTION ON
(This will enable locking of selection sets until deselecting.)
DEFINING THE TCB VARIABLE
Key-in: MDL LOAD CALCULAT
(This loads the calculator mdl application)
Key-in: CALCULATOR TCB->EXT_LOCKS.SELECTION_SET=1
(This will enable the capability to modify selection sets.)
ADDITIONAL INFORMATION
To disable the selection set lock
key-in: LOCK SELECTION OFF
OR
key-in: CALCULATOR TCB->EXT_LOCKS.SELECTION_SET=0
See also
Other language sources
