| Version: | 08.09.04.51 | ||
| Area: | Selection | ||
| Subarea: | General |
How to set Selection tool to Individ/New
How to set Element selection tool to Method "Individual" and Mode "New".
History:
When using Element Selection, it is often requested to reset the options to the default values of Mode = New and Method = Individual the tool is restarted.
Customize the tool to include the key-ins to set the desired settings.
To set Element Selection mode to New:
Key-in: POWERSELECTOR MODE NEW
To set Element selection Method to Individual:
Key-in: POWERSELECTOR SINGLE
String them together with the command to start Element Selection as follows:
POWERSELECTOR MODE NEW;POWERSELECTOR SINGLE;CHOOSE ELEMENT
Replace this command in a custom version of Element Selection.
Note: Refer to help documentation for more information on Custom tools.
