Product(s): |
MicroStation |
Version(s): |
10.03.00.30 |
Environment: |
N\A |
Area: |
Parametrics |
Subarea: |
General |
The following workflow is an example to illustrate the steps required to create a Parametric Cell using Constraints, Variables, Variations and its placement.
In this example we will create a simple 3D door leaf with an opening as a Parametric Cell, such that when a designer places the Parametric Cell they are able to choose between different types (Variations) as well as modify sizes (Variable values) as required.
This example is not intended to provide the full steps or a detailed design and it is expected a general knowledge of MicroStation and the design intent/detail is known by the designer. Further information on the tools can be found in the help and learn material.
Step 1 Place Graphics used to create the door profile
Place a couple of shapes in the design to represent the door outline and its window opening. (Note the size is not important as Dimensional Constraints will be used to control these later)
Use the Group Hole tool to create the window opening in the door
Step 2 Create Variables used to control the door and window sizes
Open the Variables dialog (Drawing > Constraints > Variables)
Create Variables for the door width, height and thickness and assign some values
Create Variables for the window opening width and height and assign some values
Create Variables to position the window opening in the door from the bottom and the side to be hinged and assign some values
Step 3 Constrain the door profile
Apply a Fixed constraint to the hinged edge of door
Apply a Perpendicular constraint from the hinged edge to base of door
Apply Parallel constraints from the hinged edge to other vertical edges
Apply Parallel constraints from the door base to other horizontal edges
Apply Dimensional constraints using the Variables created in Step 2
Step 4 Extrude the door profile to form a 3D solid
Select the Extrude tool (Modeling > Solids > Create Solids > Extrude)
In the Tool Settings dialog enable Parametric and select the Variable created in Step 2 for the door thickness
Select the door profile graphics and extrude to form a 3D solid
Step 5 Verify the Variables drive the graphics correctly and create Variations
Open the Variables dialog (Modeling > Constraints > Variables)
Review and change the Variables and verify the graphics modify as expected
Create Variations ( Different door types ) and verify the graphics modify as expected
Step 6 Enable the Model such that it canbe placed as a Parametric Cell
Open the Models and Properties dialog
Select the model created in the Models dialog
In the Properties dialog under the heading 'Cell' check 'Can be placed as cell' is set to 'True' and the 'Cell Type' is set to 'Parametric'
Step 7 Choose and placing the Parametric Cell Variations
Open the Cell Library Dialog (Drawing > Annotate > Cells )
Attach the Cell Library containing the parametric door model created earlier
Double click on the Parametric door cell to make it active and ready for placement
In the Tool Settings dialog select the required Variation
Place the Parametric cell into the design
For further information see the help and learn material
Original Author: |
Carl Myhill |
http://communities.bentley.com/products/microstation/w/microstation__wiki/30263.how-can-i-edit-the-variables-in-parametric-cells
