PDF links do not work when published to i-model
  Product: MicroStation
  Version: V8i, CONNECT
  Environment: N\A
  Area: Interchange
  Subarea: Publishing .i.dgn
Problem Description
Files that contain links to PDF files do not work when published to i-model. The link icon changes from a PDF icon to a MicroStation icon
Steps to Resolve
Try the following;
  1. In the Publish i-model(s) dialog box, expand the Publish Settings section
  2. Disable or untick the option 'Publish Linked Design Files'
  3. Click on Publish
When the generated i-model is opened, check if the link to the pdf works. The reason the link would not work is that if it is not a dgn file, the linked files will not be published. See the Help contents on 'Settings for Publishing i-models' for more information
See also
Other language sources
  Original Author: Conor King
