local license file msv8.lic not picking up partition license port
  Product: MicroStation
  Version: V8 2004, XM
  Environment: N\A
  Area: Licensing
  Subarea: General
When using SELECTserver licensing partitioning the msv8.lic license is being obtained from the default port (3998) instead of the designated port for the partitioned license.
Check the msv8.lic file to have all the entries on one line without a carage return being entered.
SERVER=servername PORT=xx.xx.xx.xx
See also
Other language sources
