Insert Company Logo
  Product(s): MicroStation
  Version(s): N\A
  Environment: N\A
  Area: Sheet Composition
  Subarea: General
How to Import Company Logo into MicroStation
Most companies have a logo that they would like to display in the Drawing Header on the sheet models. Company logos are mostly raster images which is not the ideal format to use in Drawing Headers. The solution is to Vectorize the raster image.
1.Get the graphics designer who created to raster logo to vectorize it to .DXF format.
2. Then import the .DXF logo into MicroStation.
3. If the colours are missing from the .DXF logo then get the graphics designer to give your the RGB color codes and then apply the color fills to the logo yourself.
Alternatively:
A. If you have Bentley Descartes installed then you can Vectorize the raster logo there.
  Original Author: Anders OMahony
