| Version: | MicroStation V8 XM Edition | ||
| Area: | Installation | ||
| Subarea: | General |
CD drive or access to the Internet required for product installation.
Windows Vista
Windows Vista x64
Windows XP Professional (SP2 or later)
Windows XP Professional x64
Windows XP Home Edition (SP2 or later)
Windows XP Tablet PC Edition
Windows 2000 Professional (SP3 or later)
Windows 2000 Server
Windows Server 2003 (SP1 or later)
Windows Server 2003 x64
(Windows NT, Windows 9x series are not supported)
Microsoft Internet Explorer v6.0 or later with 128-bit cipher strength
The MicroStation V8 XM Edition Software Prerequisite Pack v08.09.04.xx needs to be installed to your workstation prior to the installation of MicroStation V8 XM Edition v08.09.04. The MicroStation V8 XM Edition Software Prerequisite Pack is available from the Web downloads/MySELECT CD area of SELECTservices Online. The contents of the MicroStation V8 XM Edition Software Prerequisite Pack include:
Windows Installer 3.1v2
Microsoft .NET Framework 2.0
Microsoft .NET Framework 2.0 x64
MSXML 4 with Service Pack 2
VBA 6.4
DirectX 9c (Dec. 2006 release)
DHTML Editing Control for Applications
Important Note: The MicroStation V8 XM Edition Prerequisite Pack v08.09.04.xx needs to be installed prior to the installation of MicroStation V8 XM Edition v08.09.04 even if you have installed a previous version of the MicroStation V8 XM Edition Software Prerequisite Pack (like v08.09.00.xx or v08.09.03.xx) to the same workstation.
The minimum recommended workstation profile for running MicroStation V8 XM Edition is:
Intel® or AMD® processor 3.0 GHz or greater
256MB minimum, 512 MB recommended. More memory will almost always improve performance, particularly when working with larger models.
900MB free disk space (which includes the 400MB install footprint for a complete installation)
Graphics Card supported by DirectX 9.0. See graphics card manufacturer for latest information on DirectX drivers. If no graphics card supported by DirectX can be found, MicroStation will attempt to use software emulation under Windows XP SP2. At least 128 MB of video RAM is recommended. For optimal performance, graphics display color depth should be set to 24-bit or higher. When using a color depth setting of 16-bit, some inconsistencies will be noted.
