error "VBA not installed Fatal Error"
  Product: MicroStation
  Version: 08.01.02.15
  Environment: N\A
  Area: Installation
  Subarea: General
After a clean install of MSV8 the user received a "VBA not installed.
Fatal Error". Though MicroStation appeared to function normally.
Go into the following folder and run 'Program Files\Bentley\Program\Install\vba6\release\vba6_bentley.msi' by double-clicking the file.
If it doesn't install, it should give some reason for the failure. That information will be placed in the log files.
Contact Technical Support and have the log files read for additional information.
Log files locations:
- Program\Install\vba6\vbainstall.log
- Program\Install\SelfReg.log
