"This computer has not been restarted since this program was installed"
  Product: MicroStation
  Version: V8
  Environment: N\A
  Area: Installation
  Subarea: General
ERR: After installing Windows on a clean disk I'm getting this warning message when I start MicroStation.... "This computer has not been restarted since this program was installed. If you proceed, some operations will not work correctly. Do you want to exit this program? "
Do you have a fix to get rid of this dialogue?
go to regedit
HKEY_LOCAL_MACHINE>Software>Bentley>MicroStation>08.00
Delete the "Temporary" key
