MicroStation v8 does not open the email client if Lotus Notes is used as the default email system.
  Product: MicroStation
  Version: 08.05.02.35
  Environment: N\A
  Area: Configuration
  Subarea: General
MicroStation does not open the email client if Lotus Notes is used as the default email system.
This version of Lotus Notes is not MAPI compliant. They did not implement MAPI until V7 or later.
See also
Other language sources
