Copy w/ Fence is copying ref attachments
  Product: MicroStation
  Version: 08.09.04.51
  Environment: N\A
  Area: Selection
  Subarea: Fences
Copy w/ Fence is copying ref attachments.
When using Fence File (FF=) or copy with "Use Fence" Enabled on reference elements, the elements are not being copied from the reference as expected. It is maintaining the reference attachment or making a copy of the reference.
In previous versions of MicroStation it would not keep the reference.
Disable the "Manipulate as Element" option in reference.
Steps:
1. Open Reference dialog (File > Reference)
2. Double click on reference(s) to be changed.
3. Uncheck the option for "Manipulate as Element " in the Reference settings.
See also
Other language sources
