Modify Cells per Color and Level
  Product(s): MICROSTATION
  Version(s): 08.05.02.43
  Environment:  N\A
  Area:  Cells
  Subarea:  General
How to Modify Cells per Color and Level.
Product: MicroStation V8 2004 Edition
1. Go to File > Open.
2. Choose the cell library and open as a DGN file.
3. Go to File > Models. Here the cells are listed as models.
4. Click on the model/cell to modify and make changes. Repeat for the next model/cell and so on.
5. Once finished go to File > Save Settings.
6. When the cell library is attached, the library will reflect the new changes.
