In AutoCAD elements show correct Z value but in MicroStation shows invalid Elevation
  Product: MicroStation
  Version: V8, XM, V8i, CONNECT
  Environment: N\A
  Area: DWG
  Subarea: Save
Save to dwg and in ACAD, elements show correct Z value when using List, but Properties show invalid Elevation.
Elements are not drawn parallel to UCS. Elevation is a projection of the elements from the Z plane. To resolve, in Save As options, set Planar Line Strings to 3D Polyline. 3D Polylines do not have elevation, only Z value.
Other language sources
