How to control the Viewport Locked setting available in AutoCAD
  Product: MicroStation
  Version: 08.05.02.55
  Environment: N\A
  Area: DWG
  Subarea: Open
In the 2004 Edition of V8:
Create and set the Configuration Variable
MS_DWG_VPORT_MAP_LOCATE_OFF_TO_LOCKED
If set, the Display locked status of a viewport entity is mapped to the Locate setting of the reference attachments that represent this viewport. In this case, a viewport with Display locked off will have Locate turned off - and changing the Locate status of the reference attachment will change the Display Locked status of the viewport.
Starting in the XM Edition of V8:
In the DWG Options, it is controlled in the Reference section with the "Set Viewport Locked From Locate Off" setting.
If on, the Locked status of a Viewport will be set to the Locate Off setting from its reference attachment.
  Original Author: Erik Lofgren
