| Version: | 08.11.07.171 | ||
| Area: | Groups | ||
| Subarea: | General |
Convert lines into single linestring
How to combine/join/merge multiple lines and linestrings into a single linestring?
Product: MicroStation V8i
Version: 08.11.07.171
Area: Fundamentals
Create Complex Chain with Simplified Geometry
- activate Create Complex Chain command
- switch ON the option Simplify Geometry
- set the method to either Manual or Automatic
Follow the prompts to create the chain.
If the final chain only consists of lines and linestrings, the result will be a linestring.
