| Version(s): | 08.05.02.35 | ||
| Area: | Batch Processing | ||
| Subarea: | N\A | ||
Batch processor stops responding (freezes) after 5-10 files processed.
Product: MicroStation V8 2004 Edition
Version: 08.05.02.35
Area: Batch Processing
The Operating System on the computer that contains the files (file server)
being processed is a unsupported Platform (probably Unix).
Suggest to move the files locally and perform the batch process, then move
back to file server.
