Product(s): |
MicroStation |
Version(s): |
08.11.09.833 |
Environment: |
N\A |
Area: |
DWG |
Subarea: |
General |
This wiki includes FAQ article from Readme file of "Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016"
Current version: 08.11.09.852 since 05/16/2016
Index
- Which Bentley products does Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 work with?
- Do object enablers work with Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
- Which version of object enablers are supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
- Which versions of DWG are supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
- In MicroStation can I save as DWG files to older versions?
- Are there any features in DWG 2016 that are not supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
- Does Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 support MicroStation V8i (SELECTseries 1) or MicroStation V8i (SELECTseries 2)?
- Are Bentley enhanced object enablers available in this release?
top
1. Which Bentley products does Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 work with?
- Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 works with following Bentley products:
- MicroStation V8i (SELECTseries 4) or MicroStation V8i (SELECTseries 3)
- MicroStation PowerDraft V8i (SELECTseries 4) or MicroStation PowerDraft V8i (SELECTseries 3)
- Bentley Navigator V8i (SELECTseries 5)
- Bentley View V8i (SELECTseries 4) or Bentley View V8i (SELECTseries 3)
- Bentley PowerCivil for Country V8i (SELECTseries 3)
- Bentley PowerCivil for North America V8i (SELECTseries 3)
- Power GEOPAK V8i (SELECTseries 3)
- Power Survey V8i (SELECTseries 3)
- Power InRoads V8i (SELECTseries 3)
- Bentley MX V8i (SELECTseries 3)
- Bentley MXROAD V8i (SELECTseries 3)
- Bentley Map V8i (SELECTseries 4)
- Bentley Map Enterprise V8i (SELECTseries 4)
- Bentley Map PowerView V8i (SELECTseries 4)
- Bentley OpenPlant PowerPID V8i (SELECTseries 5)
- Bentley OpenPlant Modeler V8i (SELECTseries 5)
- AECOsim Building Designer V8i (SELECTseries 4)
- Bentley PowerRebar V8i (SELECTseries 3)
top
2. Do object enablers work with Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
Yes, this update leverages Autodesk® and other third-party object enablers to display the content stored in a DWG file that is created by an application that requires an object enabler. There are two types of object enablers. The first one is ObjectARX which runs only on AutoCAD®. It produces graphics that represents its objects. The second type is enhanced ObjectARX. In it you can add properties to these objects. This type of Object enabler runs on any RealDWG based program, including Bentley products listed above.
When using an Autodesk object enabler this update provides graphical display of AEC Objects in MicroStation, AutoCAD, and other RealDWG-based applications that support object enablers.
Object enablers may be downloaded from Autodesk® and other interested vendor's web site.
Note: In tests on Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016, it was found that some MEP files failed to open on some old x32 computers. The work around to this is saving the old file to a new file in MEP or AutoCAD.
top
3. Which version of object enablers are supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 supports AutoCAD 2016 object enablers.
top
4. Which versions of DWG are supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
To open a DWG, almost all versions of DWG are supported. To save a DWG, following versions are supported:
- 2013, 2014, 2015, 2016
- 2010, 2011, 2012
- 2007, 2008, 2009
- 2004, 2005, 2006
- 2000, 2000i, 2002
- 14
top
5. In MicroStation can I save as DWG files to older versions?
Yes, older versions of DWG files can be saved as DWG versions R14 through 2013/2014/2015/2016, as well as R12 DXF™.
top
6. Are there any features in DWG 2016 that are not supported by Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016?
There are a few capabilities that are available in MicroStation V8i and earlier editions that have not been replaced in this update. They are listed below:
- This update does not include the DWG Audit utility, but we are investigating the possibility of re-adding it in a future release.
- This update does not include the DWG Recover utility, but we are investigating the possibility of re-adding it in a future release.
If you require these capabilities and have a Bentley SELECT subscription, you may use earlier versions of MicroStation for these capabilities.
top
7. Does Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 support MicroStation V8i (SELECTseries 1) or MicroStation V8i (SELECTseries 2)?
No, Bentley V8i (SELECTseries 4) - Autodesk® RealDWG™ 2016 only supports MicroStation V8i (SELECTseries 3) and above. Please refer to the product list in question #1 above to check the release versions that are supported by different products.
top
8. Question: Are Bentley enhanced object enablers available in this release?
Yes, Bentley MX, Bentley PowerCivil, AutoPlant, and ProStructures object enablers are delivered in this release.
top
X
Other Language Sources
Deutsch
Original Author: |
Yvonne Lohse |
